  3. help on how to find the corresponding instance name
  • Views 17289
Blues
Blues over 14 years ago
In Schematic composer, there have a bus named "<*2>AA<1>,AD<3:0>,AB<1:0>" and it connect to an instance array named XDEC<7:0> 's terminal A.
Now, we can have an input string "AD<2>", how to get its connected instance name? The result should be XDEC<4>, how to writing the skill code? The property did not have the related information, maybe the probe function can help?
  • Blues
    I use a complex method to do:
    assume the bus has been selected,
    b=css()
    b~>net~>sigNames to get a list ("AA<1>" "AA<1>" "AD<3>" "AD<2>" "AD<1>" "AD<0>" "AB<1>" "AB<0>")
    search the list to get the string "AD<2>" position 3
    b~>net~>instTerms~>inst~>name to get the bus connected instance name XDEC<7:0>
    expand the instance name to get the position 3 instance should be XDEC<4>
    this method is very complicated, any one can help me for a simplified skill code?
    sig=dbFindSigByName(cvId "AD<2>")
    foreach(memInstTerm sig~>memInstTerms
      printf("Connected to pin %s on instance %s\n"
        car(memInstTerm)~>name
        dbGetMemName(car(memInstTerm)~>inst~>name cadr(memInstTerm))
    Note that this would get a bit more complicated if you were connected to a bus net on an iterated instance, but hopefully this gives you the idea in principle.
  • Blues
     Andy,
    Thank you very much, it's very clear and useful.
    Best Regards,
    Blues
  • Blues
    To solve a problem that the instance's pin can be a bus type such as A<1:0> and in this case the instance name is XDEC<3:0>, the result should be XDEC<2>, I have modified a little:
        dbGetMemName(car(memInstTerm)~>inst~>name cadr(memInstTerm)/dbGetNameNumBit(car(memInstTerm)~>name))
    your code is a very good example for me.
