  3. how to declare an array of unknown size
  • Replies 11
  • Views 30285
Sri Charan B
Sri Charan B over 14 years ago
I am trying to implement a code where i came in need of an array which can increase the size of the array during the runtime. I mean the size of the array shall not be declared using the 'declare' command but during the run time if new elements are to be added into that array i will use it or else the array shall be empty.
I need this because i am at a juncture where i cannot expect or fix the size of the array to a particular value so guys please help me.
Thanks in advance for any help,
    Andrew Beckett over 5 years ago in reply to Rameen
    Hi Rameen,
    You're asking about something completely unrelated to the topic in this thread (and also breaking all the forum guidelines by posting in a 9 year old thread). Based on a search of the error code internally, this appears to be related to the Genus product which has absolutely nothing to do with Custom IC Design or SKILL.
    I suggest you post a new question in the Digital Implementation forum.
