  3. gets() command
  • Subscribers 150
  • Views 16186
gets() command
DaveDesigner
DaveDesigner over 14 years ago
I am trying to read in a file , one line at a time but without the return character.
I am doing gets(s filename) and gets something like this "VDDA VSSA\n"
I would like to get "VDDA VSSA", any ideas how to do this?
Thank you.
**** Someone has helped me with a solution already. Thanks for reading.
car(parseString(gets(s filename) "\n"))
  • skillUser
    skillUser over 14 years ago
    Hi Dave,
    That's one way, and assuming that the "\n" is at the end of the string it should work fine.  I was going to suggest looking at rexReplace, or perhaps using substring from the start up to the length of the string - 2 (again assuming that the \n is at the end of the string).
    Lawrence.
