  3. Trigger a custom function after loading an ADE cellview...
  • Subscribers 150
  • Views 15004
Trigger a custom function after loading an ADE cellview state
iris99
iris99 over 14 years ago
I am looking for a way to call a custom SKILL function after an ADE state view is loaded both in IC5141 and IC61, so that I can force some ADE settings even if they are setup differently in the state view. Is it possible to use "deRegUserTriggers" to register a post-install function for ADE?
 Thanks.
    Did you by any chance log a service request about this (42779290)? I saw a CCR for this requirement being duplicated in the last few days.
    The answer is that there is no public trigger function to do this. The triggers that do exist (which actually are not specifically for load state, but could serve the objective) are not public and as such are not documented and liable to be changed without notice - so that's why we wouldn't propose them as a solution to your problem.
    If the service request was not from you, I'd advise contact customer support and requesting this capability, so that a further duplicate CCR can be filed, increasing the likelihood of this being implemented.
  • iris99
    Thank you, Andrew. The SR was from me.
