  3. Synchronous editing of 2 or more hierarchical layout cells...
  • Subscribers 150
  • Views 14468
Synchronous editing of 2 or more hierarchical layout cells in IC6.14
Laur9
Laur9 over 14 years ago
I have often the problem when working on top layouts to do some editing (move, strech) on actual cell and some of the sub-cells at "same time".  It should work like this : selecting something in hierarchy level 1 than you start editing in place a cell in hierarchy level 2 where you select some parts and than you want to move/strech the selected objects on both hierarchy levels,synchronous, by the same distance. Such layout operations are very tedious and error prone.
So I'm asking if there is already a layout tool that can do such jobs or a skill routine you can share with me.
Best regards
Laurent
    Laurent,
    Best thing is to contact customer support to request this as an enhancement.
