  3. Bindkey for Descend Read in layout
  • Subscribers 150
  • Views 18026
tmart
tmart over 14 years ago
Is there a function to descend into a layout as read-only, equivalent to schHiDescentRead()? I'd like to map a bindkey for that function, but can't find any documentation for it.
Cheers,
Tore
    Tore,
    leHiDescend(hiGetCurrentWindow() "read")
    will do what you want.
  • tmart
    Thanks, that did the trick.
    Best regards,
    Tore
  • tmart
     By the way, do you know if is there a list of functions in Virtuoso?
     After changing jobs, I discovered that my new employer uses Cadence more or less right out of the box and I feel an urgent need to add more functions and bindkeys for the layout editor in particular, e.g. flip object (in x and y directions), relative copy and relative move.
    Cheers,
    Tore
    From the UNIX command line, type cdsFinder . From the CIW you could type startFinder() or use the listFunctions("regularExpression") function. These are only a quick reference though - you should use cdnshelp or cdsdoc to access the full documentation for each function.
