  3. Help: how to find the location of the file "cdsLibMgr.il...
  • Subscribers 150
  • Views 6452
Help: how to find the location of the file "cdsLibMgr.il"?
Spallow
Spallow over 14 years ago
Hi, I use the unix command "find ../cadence/ic615.507/ -name cdsLibMgr" to find the location of the file "cdsLibMgr.il". where is the file? Thanks, Spallow
    Try starting the documentation (run cdnshelp from the command line, or use the Help menu in Virtuoso) and search for cdsLibMgr.il - it tells you how it is located.
    There is no cdsLibMgr.il in the standard IC installation - it's for users to add. You should be able to use "cdswhich cdsLibMgr.il" to find if you have an active file in your environment.
  • Spallow
    Hi Andrew, Thanks you, I use "cdswhich" command, there is no the file in my environment. Thanks, Spallow
  • skillUser
    skillUser over 14 years ago
    Hi Spallow,
    I'd like to add to what Andrew said.  It is possible for the cdsLibMgr.il file name itself to be customized using an environment variable in the .cdsenv file:
    cdsLibManager.customize startupFile     string  "cdsLibMgr.il"
    However, having said this, I would think that mostly the default filename cdsLibMgr.il would be used for the sake of clarity and convention.
    Best regards,
    Lawrence.
    And Lawrence's suggestion is also in the documentation that I pointed Spallow to earlier...
  • Spallow
    Thanks, Lawrence. Your suggestion is quiet useful for me. I check the variable value by the command: envGetVal("cdsLibManager.customize" "startupFile"). The value is the default name "cdsLibMgr.il".
    I have another question. I want to verify the usage of the file cdsLibMgr.il. The following two files are used to print one message when starting and closing Library Manager. However, no message output. Why?
    Spallow
    -----------      File 1: $WORKING_DIR/cdsLibMgr.il     --------------
    ; specify names of functions to call at startup and exit
    lmgrDefineInits('("abLibMgrInitProc") '("abLibMgrCloseProc"))
    -----------     File 2: $HOME/.cdsinit                         ---------------
    procedure( abLibMgrInitProc()
        fprintf(stdout  "My InitProc was called\n")
    procedure( abLibMgrCloseProc()
        fprintf(stdout "My CloseProc was called\n")
    Spallow,
    This works for me. Try putting a printf() statement in the cdsLibMgr.il file to ensure it's being loaded (it would appear at the bottom of the library manager window).
    Also, this only works with the Cadence Library Manager; if you are using somebody elses (e.g. IC Manage), then it won't work.
