  3. Help about the callback function.
  • Subscribers 150
  • Views 15353
UserSkill
UserSkill over 14 years ago
Dear all,
Attached file is my example codes.
Problem: Whenever function LibNameCB() is executed, OutDirCB() function is also called. I would like to avoid this scenario.
Please give me your advice.
 Dang Quang
conflictCB.il
    Dang,
    You'd normally solve this by using some sort of semaphore to indicate that you're in a callback. The reason why the callback gets called is because you're changing the g_OutDir field within the LibNameCB callback - and that (quite rightly) triggers the callback. If you don't want that to happen, you need to code for that. For example I modified your code to store a property on the form called inCallback which allows you to be aware of when you're in a callback. You do need to carefully make sure it doesn't get stuck such that the callbacks never do anything - essentially a state machine problem...
    conflictCB.il
  • UserSkill
     It works well. Thank you very much.
    Dang Quang
