  3. Auto Contact to different layers of metal
  • Subscribers 150
  • Views 17877
justincaalaman
justincaalaman over 14 years ago
I would like to know if it's possible to use the auto contact funtion to create vias though the different layers of metal. For example, I have a metal 1 line that needs to be connected to a metal 3 line. From what I have tried, auto contact will not work for this situation because, it only connects metal 1 to metal 2 or metal 2 to metal 3 but not metal 1 to metal 3. Is it possible to create a skill code to run the vias needed to connet these layers of metal?
I'm using IC51041
Justin
    Justin,
    In IC615, auto contact behaves just like that.
    In IC5141 you can use the "auto contact" capability in the "Turbo Toolbox" to do auto contacts between non-adjacent layers (this also supports the shapes being rectangles rather than just polygons - as in IC615). For more details, see <ICinstDir>/doc/toolboxhelp/toolboxhelp.pdf
