  3. Error in DRC run
  • Subscribers 150
  • Views 16209
Error in DRC run
venuuuuu
venuuuuu over 14 years ago
 hi guys,
         We have assura DRC rulefile which is converted from DIVA rule file. When we are run DRC for layout then it shows "Failed to bild VDB. Can not  submit DRC run". Did you have any idea?
    I'd start with solution 1842245
  • venuuuuu
      Sorry Andrew, Our host ID and entitlement is expired.
    The most likely reason:
    There are syntax errors in the DRC rules file. The CIW will only list the first syntax error detected in the rules file, so it’s recommended to test the rules file by running a job using the avParameters command ?compileOnly t in the RSF from the Unix prompt until you make sure your DRC rules file is completely free of syntax errors.
