  3. Export Image
  • Views 19113
Export Image
ahata
ahata over 14 years ago
 I'm runing an skill code which generates all layouts automatically and I would like to export an image of each layout. I am using the comman:
deOpenCellView( libName cell "layout" "maskLayout" wid "r")
hiExportImage(?fileName imagePath ?bBox list(llx:lly urx:ury) ?width  nwpix ?window wid)
 which if I am bit wrong generates an image of the layout that is opened in a windows wid.
 My question is if there's a way to generate the image without opening the window. Since I'm actually taking several images, opening the windows is time consuming.
 Thanks in advance for your help
    You can either do it like this:
        ; Open a window and export it.
        ; If using IC613 ISR13 or later, you can use "none" in the call
        ; to hiCreateWindow below. Otherwise change it to be "graphics"
        ; (the difference is that the window will then appear briefly)
        ;; Similar to thumbnail code...
        dd=ddGetObj( lib cell view "*")
        viewType=ddMapGetFileViewType(dd)
        ; was none rather than graphics
        wid = hiCreateWindow( list(0:0 800:800) "none" "Export Window")
        wid->neverCurrentWindow = t
        deOpenCellView( lib cell view viewType wid "r")
        sprintf(imageFile "tbIMG_%s.png" testName)
        hiExportImage(
          ?fileName strcat(datasheetDir "/" imageFile)
          ?exportRegion 'entireDesign
          ?bgType 'transparent
          ?window wid
        hiCloseWindow(wid)
    Or you could use hiGenerateThumbnails() to do this - it has (from IC615 onwards) a ?filePath argument which allows you to generate the "thumbnail" (which can be whatever sizes you want) to a file outside the cellView.
  • ahata
    Many thanks for your help again,
    Now I'm able to create the images without opening the windowsin the graphics mode. I think that my code wasn't working since I was calling the  deOpenCellView before the wid->neverCurrentWindow statement.
     Sorry for answering you back that late, but I was trying to apply the Calibre drc and lvs through an SKILL script and I did no have time to check your answer about the image
     Thanks!!!
    best regards
     Sergio
