  3. Assura OA version DRC form
  • Subscribers 150
  • Views 15125
sandeepc
sandeepc over 14 years ago
We use assura for DRC verification in Cadence 6.1.5. I am using the following code(Source : Cadence) below to create the directories for run.
when I open the LVS and ERC forms from the Assura menu the direcotory information is filled. But when I open the DRC form it prints an error.
*Error* strcat: argument #4 should be either a string or a symbol (type template = "S") - nil
Here is the code I am using.
procedure( vuiUserDefinedSetupCB(formHandle)
   let( (newDir libName cellName runType)
      if(formHandle->layoutSource->value=="DFII" then
         libName=formHandle->layLibrary->value
         cellName=formHandle->layCell->value
      else
         libName="streamFiles"
         cellName=formHandle->layCellName->value
      ) ;if
      case( formHandle->hiFormSym
          (vuiDRCForm runType="DRC")
          (vuiLVSForm runType="LVS")
         (vuiERCForm runType="ERC")
      ) ;case
      unless( isDir("./VERIFICATION")
 csh("mkdir ./VERIFICATION")
      ) ;unless
      unless( isDir(strcat("./VERIFICATION/" runType))
 csh(strcat("mkdir ./VERIFICATION/" runType))
      ) ;unless
      unless( isDir(strcat("./VERIFICATION/" runType "/" cellName))
 csh(strcat("mkdir ./VERIFICATION/" runType "/" cellName))
      ) ;unless
      newDir=strcat("./VERIFICATION/" runType "/" cellName "/" libName)
      formHandle->runDir->value=newDir
   ) ;let
Any clues?
Sandeep.
  • Quek
    Quek over 14 years ago
    Hi Sandeep
    Assura DRC form uses "formHandle->format->value" instead of "formHandle->layoutSource->value". You can use the following script:
       let( (newDir cellName runType inputSym cellSym)
          case( formHandle~>hiFormSym
             (vuiDRCForm runType="drc" inputSym="format" cellSym="cell")
             (vuiLVSForm runType="lvs" inputSym="layoutSource" cellSym="layCell")
             (vuiERCForm runType="erc" inputSym="layoutSource" cellSym="layCell")
             (t runType="svs")
          ) ;case
          unless( evalstring(strcat("formHandle~>" inputSym "~>value"))=="DFII"
             case( runType
                ("drc" cellSym="cellName")
                (("erc" "lvs") cellSym="layCellName")
             ) ; case
          ) ;unless
          cellName=evalstring(strcat("formHandle~>" cellSym "~>value"))
          newDir=strcat("./av" upperCase(runType))
          unless( isDir(newDir)
        csh(strcat("mkdir " newDir))
          ) ;unless
          newDir=strcat(newDir "/" cellName)
          ) ;unless
          formHandle~>runDir~>value=newDir
       ) ;let
    ) ;procedure
    Best regards
    Quek
  • sandeepc
    Hi Quek,
    thanks for the help. It works.
    Sandeep.
