  3. customize tools in cadence ADE
  • Subscribers 150
  • Views 14626
imagesensor123
imagesensor123 over 14 years ago
Hello All,
  i am trying to insert a customized tool in the cadence ADE, and now i meet a problem, i need to copy some components in the schematic in backgroud, and add the "copyed ones" in parallel with the original component, for example, i draw a invertor  with input and output in schematic composer, and i would like to copy 9 invertors more when i start simulation with my own tool, and the 10 invertor ouput node will be connected togeter automaticlly, i think it is better to do this by modifying the netlist, thanks for your suggestion.
  • Quek
    Quek over 14 years ago
    Hi zfeng
    Would it not be easier to simply use an iterated instance name for the schematic inverter? E.g. from I0 to I0<0:9>. ADE will generate 10 inverters during netlisting.
    Best regards
    Quek
  • imagesensor123
    Hi Quek,
         yes, your method works fine, thanks for your advice.
