  3. get shape attributes
  • Subscribers 150
  • Views 15453
ahata
ahata over 14 years ago
I would like to get the layotu attributes, such as the layerName and bbo. The following code allows me to do it
               cv = geGetWindowCellView( wid )
               layer = "PO"
               poly = length(setof( shape cv~>shapes shape~>layerName == layert  ))
However this code requieres the layout to be opened in a windows. Can I get the shape attributes without opening a windows?
 I tried this, but it did not work...
cvId = dbOpenCellViewByType( ALO_LIB_ID cellVariant "layout" "maskLayout" "w" )
numShapes = length(setof( shape cv~>shapes shape~>layerName == "M1" ))
This code does not get the number of shapes..
  • Quek
    Quek over 14 years ago
    Hi Ahata
    You should not be using "w" mode as it erases the original contents of the cellview. You should open the cellview in read-only mode:
    cv=dbOpenCellViewByType(ALO_LIB_ID cellVariant "layout")
    Best regards
    Quek
