  3. How to bring a window to top
  • Views 17296
MLindig
MLindig over 14 years ago
 what is the best solution to bring a window to foreground (the most top one) if it is behind some others. Currently I use:
(hiUnmapWindow wid)
(hiMapWindow wid)
but it flickers for windows which are always on top.
Michael
    Michael,
    hiRaiseWindow()
  • MLindig
    Andrew,
    does not work for me!? I have a remote X-Session and if I use hiRaiseWindow(wid) then nothing will be changed. Only the unmap/map works.
    Michael
    Program:                @(#)$CDS: icfb.exe version 5.1.0 06/20/2007 02:13 (cicln03) $
    Michael,
    Well, it works for me. If the window is minimized (iconified) then hiRaiseWindow alone won't do the trick - you might need hiDeiconifyWindow() as well.
    Other than that, it may be a limitation of whatever window manager you're using? Do you know what that is?
  • MLindig
    Andrew,
    ok I think it may depend on my special setup. I work on a Win7 with XMing X-Server and be connected to a linux compute server with SSH-XForwarding.
    My unmap/map method works stable for me and I think the flicker issue is OK.
    Thanks Michael
    Michael,
    OK, that's not really surprising then.
