  3. Ring with 45 degrees
  • Views 14906
SuperHot
SuperHot over 14 years ago
 Hi. Im new to skill pcell coding.
I made a  ring and inserted in in techfile using MPP.
However, I want to make one with "45 degrees" corners?
How is this possible to techfile?
    Your question is a bit confusing. First of all, the MPP is not a pcell. Secondly, the template doesn't define how you draw it - that is when you create a multipart path using the template - you can create multi-part paths with 45 degree segments.
