  3. Query with forms
  • Views 16477
Query with forms
ank0888
ank0888 over 14 years ago
Hi all
 I am trying to create a very simple form where a part of the operation involves selecting an instance from the layout and having it displayed in the String box field
Flow as below:
instSelField = hiCreateCyclicField(
      ?name           'instSelField
      ?choices        list("None" "Select from EV View")
      ?prompt         "Select from"
      ?defValue        "None"
      ?callback        "GetCellInstance()"
);inpSelTypeField
instDisplayField = hiCreateStringField(
      ?name          'instDisplayField
      ?prompt         "Instance Name"
      ?value          "none"
      ?defValue        value
      ?editable        t
value=GetCellInstance()
  procedure(GetCellInstance(f)
  prog((cell_view xx)
  cell_view=geGetEditCellView()
  if(frmSel="Select from V
  xx=car(geGetSelSet()~>name)
  println(xx)
  return(xx)
RNetFileForm =hiCreateAppForm(
?name `RNetFileForm
?formTitle "Create R network Schematic"
?callback `RNetFileFormCB
?fields list(inpSelTypeField instSelField instDisplayField)
?help " "
?unmapAfterCB t
hiDisplayForm(RNetFileForm)
What I want to have is the following:
1. After selecting "Select from EV View", from instSelField, I want to be able to select the instance from the Layout view (Extracted view or layout)
2. The selected instance name should appear on the instDisplayField
I tried assigning the return value of the procedure that gets the instane name to defValue in instDisplayField but it never gets assigned.
I also need to be able to do this instance selection only when "Select from EV view" is clicked.
Any help?
  • ank0888
    Correction in the procedure: procedure(GetCellInstance(f) prog((cell_view xx) cell_view=geGetEditCellView() xx=car(geGetSelSet()~>name) println(xx) return(xx) ) )
  • ank0888
    Hello
     I am working on an application where I need to be able to do the following:
     Steps:
    1. I have created a form where with a Cyclic field -Field 1 (choice ->None and Select from Layout)
    2. After clicking "Select from Layout",  I select the instance from the layout view.
    3. I want the instance name to be immediately populated in a string field in the form -Field2
    I have put a procedure in the Callback in Field1 that gets the Instance name. However, the trouble is that the instance name gets populated in Field 2 only after an additional click on Field 1 (Ie change choice from Select from Layout to None). Clearly this  should not be the flow .
     I realize that the callback from Field1 is called immediately on click and the procedure is executed fully. Hence a second selection is required to enable transfer of data (geGetSelSet()) from layout to form.
     Is there a way to overcome this.
     What I want to finally have is something like what is present in cadence tools. Eg : Cadence ADE  ->Select Net from Schematic -> (On selecting net from schematic)--> Net name is populated in ADE form
      Skeleton code as below:
    ; FIELD1
    pinSelField = hiCreateCyclicField(
          ?name           'pinSelField
          ?prompt         "Select Pin"
          ?defValue        "None"
          ?callback        "GetPinInstance()"
    );inpSelTypeField
    ;PROCEDURE TO GET CELL NAME
    procedure(GetCellInstance(frm frmSel)
    prog((cell_view xx)
       cellSelect=geGetSelSet()
       cellName=car(cellSelect~>name)
         if(!cellName then cellName ="none")
       RNetFileForm->instDisplayField->value =cellName
    ;FIELD 2 (Display Instance Name
          ?value          "none"
          ?defValue      "none"
          ?editable       t
  • dmay
    dmay over 14 years ago
    I have just a couple of observations from your code in your post:
    1. You said in step 2 that "After clicking "Select from Layout",  I select the instance from the layout view". Your callback runs as soon as you toggle that cyclic field. At that time, it looks to see what is currently selected. If you want to select the instance after you toggle the cyclic field, you'll need to use an enter function like "enterPoint" and process the instances under the point. This would be better implemented with a button since toggling the cyclic field back to "none" would be the only way to get the callback to run again. As the code is now, you can have the user select an instance in the layout first and then press a button on the form that calls the callback and that would work without need for an enter function.
    2. Your pinSelField callback calls GetPinInstance. The callback you posted is named GetCellInstance.
    Derek
  • ank0888
    Hi Derek
    Sorry for the delayed response.
    I got this resolved. Resorted to usage of buttons and fixed the problem as usage of enterPoint would not fully satisfy my requirement(double toggle)
    Thanks for the guidance. I do not see the post on the community forum. Hence the reply
    Anukul
