  3. Various Cell Combinations
  • Views 14556
Sridhar Bhat
Sridhar Bhat over 14 years ago
Could someone help me out in writing a code which places the instances of all mentioned cells in various combinations. For example if I have 3 cells(ex X ,Y and Z) mentioned in a list then I need to  have 2^3 combinations.
Thank you
Sridhar,
    Well, to generate the permutations (not 2^3 combinations, it would be N! - so 6 if there are 3 cells), you could use this SKILL function:
     (defun abPermsUniqueList (l)
      (if (null l) '(nil)
        (mapcan (lambda (x)
              (mapcar (lambda (y) (cons x y))
                  (abPermsUniqueList (remove x l )))) l)))
    That will work fine provided that there are no repetitions in the list passed in - so abPermsUniqueList('("X" "Y" "Z")) will produce:
     (("X" "Y" "Z")
        ("X" "Z" "Y")
        ("Y" "X" "Z")
        ("Y" "Z" "X")
        ("Z" "X" "Y")
        ("Z" "Y" "X")
    If there are repetitions, then you would need to use the SKILL++ code (make sure it's in a file with a ".ils" suffix) - it uses a local function:
    (defun abPerms (l)
      ; Local function to remove only the first match in a list
      ; which means that it copes with repeated values in the list
      (defun removeFirst (val l)
        (let (found)
          (setof elem l
             (cond
               (found t)
               ((equal val elem) (setq found t) nil)
               (t t)
      (if (null l) '(nil)
        (mapcan (lambda (x)
                  (abPerms (removeFirst x l )))) l)))
    I'll leave it to you to do the placement of the instances.
