  3. Help on code that identifies cellnames which contains specified...
  • Views 14524
Help on code that identifies cellnames which contains specified device
Sarvani
Sarvani over 14 years ago
 hi experts,
                 I am  trying for a code  that shows cellnames which contains device what I specified. And it also counts how many devices through "counter"(variable). Code works for top level only. But I need hierarchy also.
counter=0
procedure(CCFfindViewsUsed(@optional
    (cv geGetEditCellView())  cellsfound
    (visited makeTable('visited nil)))
  foreach(master cv~>instances
    unless(visited[master]
      visited[master]=t
      if(strcmp(master~>cellName "INV")==0 then
        counter++
unless(member(cv~>cellName cellsfound)
      cellsfound=cons(cv~>cellName cellsfound)
      cellsfound=CCFfindViewsUsed(master cellsfound  visited)
cellsfound
Thankyou
  • Quek
    Quek over 14 years ago
    Hi Sarvani
    Here is some sample codes to do a hierarchical search for empty cells. Perhaps it can study it and implement the hierarchical search for your script. : )
    Best regards
    Quek
    procedure( CCSdeleteEmptyCells(lib cell view)
       let( (cv)
          cv=dbOpenCellViewByType(lib cell view "" "a")
          CCShierarchicalSearch(cv list())
       ) ;let
    ) ;procedure
    procedure( CCShierarchicalSearch(cv cellList)
       prog( (masterList cvm)
          foreach(inst cv~>instances
             if(inst~>master && inst~>master~>bBox != list(0:0 0:0) then
                masterList=cons(inst~>master masterList)
             else
                printf("Removing empty inst %s using cell %s\n" inst~>name inst~>cellName)
                dbDeleteObject(inst)
             ) ;if
          ) ;foreach
          foreach(master masterList
             cvm=dbOpenCellViewByType(master~>libName master~>cellName master~>viewName)
             cellList=cons(master cellList)
             CCShierarchicalSearch(cvm cellList)
             dbClose(cvm)
          ) ;foreach
          return(t)
       ) ;prog
    ) ;procedure
