  3. print quote mark in the string( apologize if it has been...
  • Views 18047
print quote mark in the string( apologize if it has been posted too many times)
imagesensor123
imagesensor123 over 14 years ago
Hi all,
   i would like to use the command in shell:
  grep "Vout" capinfo.txt > cap.out
so the problem is how to generate this for ipcProcess, some others posted this in this forum, but i hasn't been well solved.
so let's make it clearly.
i have tried strcat("grep" "\"" " Vout" "\"" "capinfo.txt>cap.out" ) =>"grep \"Vout\" capinfo.txt>cap.out",
owing to these two backslash , the script can not be exacuted in shell.
could you help me?
    Your command has spaces in the wrong places. If I do:
     command=strcat("grep " "\"" "Vout" "\"" " capinfo.txt>cap.out" )
    then command returns this:
    Note that the backslashes are not really there - this is just the print representation. For example, if I do:
    printf("THE COMMAND IS [%s]\n" command)
    then it outputs:
     THE COMMAND IS [grep "Vout" capinfo.txt>cap.out]
    and I can happily do:
    sh(command)
    and it works perfectly. If the backslashes bother you, you could always do:
      command=strcat("grep " "'" "Vout" "'" " capinfo.txt>cap.out" )
    i.e. use single quotes, to get:
     "grep 'Vout' capinfo.txt>cap.out"
  • imagesensor123
      thanks, it works well, and i get the following results:
    Vout : Vout     fixed=63.8 a       variable=5.58258 f    sum=5.64638 f
    Vout : Vout     fixed=63.8 a       variable=5.60251 f    sum=5.66631 f
    Vout : Vout     fixed=63.8 a       variable=5.65443 f    sum=5.71823 f
    Vout : Vout     fixed=63.8 a       variable=7.12683 f    sum=7.19063 f
    Vout : Vout     fixed=63.8 a       variable=7.09192 f    sum=7.15572 f
    Vout : Vout     fixed=63.8 a       variable=7.02311 f    sum=7.08691 f
    Vout : Vout     fixed=63.8 a       variable=5.69755 f    sum=5.76135 f
    Vout : Vout     fixed=63.8 a       variable=5.70667 f    sum=5.77047 f
    Vout : Vout     fixed=63.8 a       variable=5.72751 f    sum=5.79131 f
    Vout : Vout     fixed=63.8 a       variable=5.71754 f    sum=5.78134 f
    how can i get the value in the last column? i mean , i want to get the value 5.64638f for the first row,
    and 5.66631 for the second row? thanks
    There's definitely an echo in this forum. Can't you adapt the scripts I gave in this earlier post, which are pretty similar to your requirements here. Possibly even identical.
  • ANSYS
    ANSYS over 5 years ago in reply to Andrew Beckett
    I have a similar request and I used the "\"" approach but it still doesn't work for the arguments. In my case I'm trying to open a csv file like below:
    csvinput="C:\\temp\\tmp space\\mydata.csv"
    path=axlGetVariable("CURRENT_OFFICE_VERSION")
    cmdOpenCSV=strcat( "\"" path "\\EXCEL.EXE" "\" \"" csvinput "\"" )
    cid = ipcBatchProcess(cmdOpenCSV "" "c:\\temp\\skill_log.txt")
    If I place mydata.csv on a folder without spaces, it works. Also, strangely enough the "\"" worked for excel's path as it also has white spaces. Could you please comment on that?
    Thanks in advance.
    Andrew Beckett over 5 years ago in reply to ANSYS
    This is probably not the best place to ask this question - you're using SKILL with the Allegro platform (not Custom IC) and so you'd be better off asking this in the PCB SKILL forum (the forum guidelines ask you not to post on the end of old threads anyway, especially as this one is 9 years old).
    Since I don't have the Allegro tools installed on Windows (and they're not my area of expertise), I can't really do some tests to see how this works or figure out which things you need to quote or escape. So please ask this again in the PCB SKILL forum.
