  3. string concatenation with cadence SKILL
  • Subscribers 148
  • Views 26608
gte582
gte582 over 13 years ago
Hi, I wonder how to concatenate these strings with SKILL in IC5.10.41:
VT
/out
So that I have a transient voltage net at the end such as
VT(“/out”)
which I can use the plot command to plot in a WaveScan window?
I mainly have difficulty to insert those double quotes inside
that string.
    Why would you need to concatenate these? Can't you just do:
    signal="/out"
    plot(VT(signal))
    If for some odd reason you needed to build a string containing the expression above, you could do:
    signal="/out"
    expr=strcat("VT(\"" signal "\")")
    but I don't see why you'd need to do that. Usually it's because people are using the wrong approach and using evalstring() to do evaluation of an expression unnecessarily.
  • gte582
    Thanks, Andrew. The first one did plot the signal correctly, but it shows VT(signal)
    as the curve name. How to show  VT("/out")  instead?
    For the second one, that is exactly what I confused about the capability
    of strcat function as it outputs VT(\"/out\") instead of VT("/out") ?!
    You could use
    plot(VT(signal) ?expr list(signal))
    to show the signal name as the name of the signal.
    Andrew=
  • gte582
    Yeah, but it will only show /out not VT("/out"), like you'd manually plot
    that transient signal, right? Thanks,
    If you really want it to show that expression, you'll either need to pass the strcat I showed earlier:
    plot(signal ?expr list(strcat("VT(\"" signal "\")")))
    Or use:
    awvPlotWaveform(currentWindow() list(signal))
    If there's no existing window, you'll need to call newWindow() first.
    Note, I did no testing of these - this is from memory - so apologies if there are any typos.
    Andrew=
  • gte582
    That works! Thanks, Andrew.
