  3. how do you toggle between enterPoint() and enterBox()
  • Replies 15
  • Views 22813
Adhil
Adhil over 14 years ago
Hi
I am trying to create this align function that functions similarly to that of icstation.
the following describes how the macro is used
1. you select the object that you want to move to align
2. invoke the align function via a bindkey
3. the function prompts you to enter a point which it then uses to select the reference object.
4. complete the action by moving the initially object and aligning it to the reference object.
 how can i make the selection of the reference object be versatile so that i can click to select a reference object or draw a box to select multiple reference objects. i was thinking of a function  that can toggle between enterpoint() or enterbox(), but i dont know how to do this. please help.
thanks
Adhil
  • dmay
    dmay over 14 years ago
    Take a closer look at the code.
    1. In the drawThru1Bk code, the "case" command will run CreateAlignSet if either "xAlign" or "yAlign" is running. It doesn't matter which command is running since CreateAlignSet simply selects some items. As I suggested in my last post, this should be made more generic since there are not two separate enter functions. Setting the cmdName to "myAlign" and checking only for that command would be a cleaner way to do it.
    2. No, you cannot make bindkeys be function specific. That is why I implemented it like I did. This drawThru1Bk procedure could be expanded to do many different functions for many different commands. It is similar to cmdOption() or lxCmdOptions() bindkey functions that you might find on your right or middle mouse buttons (depends on your Cadence version). These functions do different things depending on the command you run. For example, if you are moving a via, and use one of these bindkeys, your via will rotate. However, if you use the same bindkey during a split command it will toggle how an item will be split.
    Derek
  • Adhil
    in a similar note i tried to impliment the flip command to my right mouse key while a object is moving. here is the code.
    hiSetBindKey("Layout" "<Btn3Down>EF" "adhFlip()")
    procedure(adhFlip()
    let(((changeFlag 0) (object car(geGetSelSet())))
    if(hiGetCurrentCmd(hiGetCurrentWindow()) == "Move" then
     when(object~>orient == "R0" && changeFlag == 0
      object~>orient = "MX" changeFlag = 1)
     when(object~>orient == "MX" && changeFlag == 0
      object~>orient = "MY" changeFlag = 1)
            when(object~>orient == "MY" && changeFlag == 0
      object~>orient = "R0" changeFlag = 1)
    this function does not work at all, when i replaced it with the following
    procedure(adhFlip()
     leHiFlip()
    the object flips and gets placed, as opposed to being in the "move" mode.
  • Adhil
    Hi
    I did the following alterations to the code, so i can align partially selected paths to given objects. it does work, but it does not align. it is because it is hard to retrieve the points of the partially selected part. how can i find these coordinates, here is the code.
    procedure(myAlign(dir)
    let((objects obj shift sourceBox refObjects refBox pt (parSelectFlag 0))
        objects = geGetSelSet() ; selects objects to be moved to align
        if(length(objects) == 1 && geIsFigPartiallySelected(car(objects))
             then parSelectFlag = 1)
        pt = enterPoint(                   ; prompts the user to enter a point which will be used to select the reference object
          ?prompts list("Select the ref object")
          ?addPointProc "myAddPointProc"
          ?initProc "setSelectionMode"
          ?cmdName "myAlign"
        sourceBox = trBBoxUnion(objects~>bBox)
        if(refObjects = setof(x geGetSelSet() !memq(x objects))
            refBox = trBBoxUnion(refObjects~>bBox)
            refBox = list(pt pt)
        if(dir == "X"
            shift = list(getXshift(sourceBox refBox) 0)
            shift = list(0 getYshift(sourceBox refBox))
        if(dir == "center" then
         Xshift =   getXshift(sourceBox refBox)
            Yshift =   getYshift(sourceBox refBox)
            shift = list(Xshift Yshift)
        foreach(obj objects
         if(parSelectFlag == 1 then leStretchShape(obj shift geGetSelSetFigPoint(obj) t ) else
          dbMoveFig(obj geGetEditCellView() list(shift "R0"))
        geDeselectAll()
        mapcar('geSelectObject objects)
    procedure(myAddPointProc(win pt)
    Adhil
  • dmay
    The first function works a little. However, it is flipping the object that is placed while you are in the middle of a move command. The "ghost" that is displaying on the screen as you do your move will not show the flip, but the placed object will and when your move is complete it will be flipped. I found that the second command worked even worse.
    If you want to flip something during a move, use the lxCmdShiftOptions() bindkey. You should find this on either shift<Btn3Down> or shift<Btn2Down>.
    Derek
  • dmay
    If you are using the code I sent you then you'll need to adjust the getYshift and getXshift commands since they use the centerBox for determining the offset. Your original request was to work from the center axis, now you are aligning edges. Again, may I suggest the Quick Align which does edges perfectly. Otherwise, you need to modify your code for determining your offset so that it can handle edge alignments as well as center alignments. Sounds like you might need to create an options form for this enter function.
     Derek
