  3. how do you toggle between enterPoint() and enterBox()
  • Replies 15
  • Views 23013
Adhil
Adhil over 14 years ago
Hi
I am trying to create this align function that functions similarly to that of icstation.
the following describes how the macro is used
1. you select the object that you want to move to align
2. invoke the align function via a bindkey
3. the function prompts you to enter a point which it then uses to select the reference object.
4. complete the action by moving the initially object and aligning it to the reference object.
 how can i make the selection of the reference object be versatile so that i can click to select a reference object or draw a box to select multiple reference objects. i was thinking of a function  that can toggle between enterpoint() or enterbox(), but i dont know how to do this. please help.
thanks
Adhil
  • dmay
    dmay over 14 years ago
    One way is to use the changeEnterFun() command. You could activate this command with a bindKey or radio button on your form to toggle between enterPoint and enterBox.
    Another way is to define the EF feature of one of your mouse draw-thru keys to do what you want.
    hiSetBindKey("Layout" "<DrawThru3> EF" "myCommand()")
    When you write "myCommand" it can check the result of hiGetCurrentCmd to make sure it only operates when your command is running. You'll need to use the ?cmdName argument to enterPoint and will probably need to use something like finishEnterFun or applyEnterFun.
    There may be other ways to do it as well. Search the Cadence docs for "enterFun" and see what works best.
    Derek
  • Adhil
    this is my code
    procedure(xAlign()
    let((objects obj somepoints refObject shift overallbbox)
    objects = geGetSelSet() ; selects objects to be moved to align
    somepoints = enterPoint(                   ; prompts the user to enter a point which will be used to select the reference object
      ?prompts list("enter the ref object")
      ?doneProc "adhGetSelSet"
      ?initProc "setSelectionMode"
    geAddSelectPoint(hiGetCurrentWindow() nil somepoints) ; selecting the reference object
    refObject = car(last(geGetSelSet()))
    overallbbox = makeInstance('overallbbox ?bBox trBBoxUnion(objects~>bBox))
    println(overallbbox~>bBox)
    shift = getXshift(overallbbox refObject)
    foreach(obj objects
    dbMoveFig(obj geGetEditCellView() list(shift:0 "R0")))
    geDeselectAll()
    procedure(setSelectionMode(win)
    geSetEnterFunctionSelectionMode(win 4)
    procedure(trBBoxUnion( bBoxList )
    let((llxList llyList urxList uryList minllx minlly maxurx maxury)
    llxList = foreach(mapcar bBox bBoxList xCoord(lowerLeft(bBox)))
    llyList = foreach(mapcar bBox bBoxList yCoord(lowerLeft(bBox)))
    urxList = foreach(mapcar bBox bBoxList xCoord(upperRight(bBox)))
    uryList = foreach(mapcar bBox bBoxList yCoord(upperRight(bBox)))
    minllx = apply('min llxList)
    minlly = apply('min llyList)
    maxurx = apply('max urxList)
    maxury = apply('max uryList)
    list(minllx:minlly maxurx:maxury)
    defclass( overallbbox ()
     (bBox @initarg bBox)
    procedure(getXshift(object ref)
    let((shift objectMidx refMidx)
     objectMidx = (xCoord(lowerLeft(object~>bBox))+xCoord(upperRight(object~>bBox)))/2
            refMidx    = (xCoord(lowerLeft(ref~>bBox))+xCoord(upperRight(ref~>bBox)))/2
    shift = refMidx - objectMidx
    shift
    hiSetBindKey("Layout" "Super<Key>x" "xAlign()")
    how can i tell xAlign() to use enterpoint() (shown in Bold)  when i "click" or use enterBox() when i "click and drag".
  • dmay
    I think you can probably do what you are asking, but I'm beginning to wonder why? First of all, there is a great alignment tool in 6.1.5 called leHiQuickAlign that would do what you want and more. Are you using 6.1? If not, have you tried leHiAlign (in 5.1.41)? Before I try to provide you some help to your question I think you should look into Cadence align features before re-writing an IC Station align, especially since Quick Align lets you pick edges and space by rule etc.
    Second, how does a selected set work better than a single point when you are setting up a reference point for alignment? You are going to have to process that selected set and come up with a single point anyway. What is the benefit of doing that?
    Derek
  • Adhil
    Hi Derek
    I am aware of  lehialign and th leHiQuickAlign, however, LeHiAlign is quite difficult to get around and leHiQuickAlign() can be quite buggy as it does not properly hilight the areas that i want the selected items to align to.
     the icstation align tool is very easy to use. and i love it.
    1. you can partially select a vertice and align it to any object.
    2. you can select multiple objects and it can align the common centre to any reference object.
    3. the whole procedure is quite intuitive.
    therefore, by recreating the three align modes that i most often use, i.e x center x centre align, y center y centre align and centre centre align, and allocating bind keys to each align function, i can improve my productivity. i feel that  always invoking a form when you want to align something to be very cumbersome, especially when you use only three of the functions.
    the reason why this question was posed is that i want to have the option of aligning the common  centre of a selected group of objects to the common centre of a selected group of reference objects.
    I hope you can help me out
    Adhil
  • Adhil
    ::::::::::::::::::::::::::::::::::: (ref object B)
    ::::::::::::::::::::::::::::::::::: (ref object C)
                                                :::::::::::::::::::::::::::::: (object A)
    1. select object A
    2. press bindkey for "y centre y centre align"
    3. draw selection bbox to select ref object B and C together.
    then
  • dmay
    Is Quick Align buggy, or it just doesn't let you hilight the common center of the selected objects? I find it very useful and the form is definitely not needed. I agree leHiAlign is cumbersome, but only mentioned it in case you were running 5.1.41 where Quick Align doesn't exist.
    1. You can partially select a vertice and align it to any object using Quick Align
    Partially select the edge, press the quick align bindkey, double click the destination edge
    2. You can almost do this, but you cannot choose the common center. In my experience this is not a problem because there is always an edge I can use for aligning. Select all the objects, press the quick align bindkey, pick the edge in your selection and the destination edge.
    3. Quick Align takes a little practice but is feature rich. Using your right mouse button there are a couple options for setting a veritical or horizontal target axis. You can align all objects individually with a double click and the whole group with a single click. It can see through hierarchy. Seems like you could ask for an enhancement for common center.
    Derek
  • dmay
    Try this:
    procedure(xAlign()
        myAlign("X")
    ) ;proc
    procedure(yAlign()
        myAlign("Y")
    ) ;proc
    procedure(myAlign(dir)
    let((objects obj shift sourceBox refObjects refBox pt)
        pt = enterPoint(                   ; prompts the user to enter a point which will be used to select the reference object
          ?prompts list("Select the ref object")
          ?addPointProc "myAddPointProc"
          ?cmdName "xAlign"
        sourceBox = trBBoxUnion(objects~>bBox)
        if(refObjects = setof(x geGetSelSet() !memq(x objects))
            refBox = trBBoxUnion(refObjects~>bBox)
            refBox = list(pt pt)
        if(dir == "X"
            shift = list(getXshift(sourceBox refBox) 0)
            shift = list(0 getYshift(sourceBox refBox))
        foreach(obj objects
          dbMoveFig(obj geGetEditCellView() list(shift "R0"))
        geDeselectAll()
        mapcar('geSelectObject objects)
    procedure(myAddPointProc(win pt)
        geAddSelectPoint(hiGetCurrentWindow() nil car(pt)) ; selecting the reference object
    ) ;proc
    procedure(setSelectionMode(@optional (win hiGetCurrentWindow()))
    procedure(getXshift(srcBox refBox)
      let((x1 x2)
        x1 = car(centerBox(srcBox))
        x2 = car(centerBox(refBox))
        x2-x1
      ) ;let
    ) ;proc
    procedure(getYshift(srcBox refBox)
      let((y1 y2)
        y1 = cadr(centerBox(srcBox))
        y2 = cadr(centerBox(refBox))
        y2-y1
      ) ;let
    ) ;proc
    procedure(CreateAlignSet()
      let((pts)
        pts = enterBox( ?prompts list("Select the ref objects"))
        geAddSelectBox(hiGetCurrentWindow() nil pts) ; selecting the reference objects
        cancelEnterFun() ;Cancels the enterPoint that started this whole thing
      ) ;let
    ) ;proc
    ;This is necessary otherwise you'll lose the default functionality
    ;that allows geSingleSelectBox to work during other enterFunctions
    procedure(drawThru1Bk()
        case(hiGetCurrentCmd(hiGetCurrentWindow())
            (("xAlign" "yAlign")
                CreateAlignSet()
            (t
                geSingleSelectBox()
    ) ;proc
    hiSetBindKey("Layout" "<DrawThru1> EF" "drawThru1Bk")
    hiSetBindKey("Layout" "<Key>x" "xAlign()")
    hiSetBindKey("Layout" "<Key>y" "yAlign()")
  • Adhil
    Thank you so much for the code, just a few questions
    1. Why did you define the ?cmdName in enterPoint
    I tested it, the function does not work as intended, you have to select the ref objects and then click again for the objects to align. However, if you define cmdName, then it works. And why did you enter the string "xAlign" as the value for this.
  • dmay
    The drawThru1Bk function that is defined on the drawThru1 enter function bindkey checks to see what function is running. It only does what you need it to do when the function name matches your command. Otherwise, it runs the command that was originally defined on the drawThru1 bindkey.
    For example, if you have nothing selected and you start the Cadence stretch command, you can select items to stretch using the drawThru1 bindkey. If I had simply replaced the drawThru1 bindkey with a custom command, this functionality would be lost. Now, if you start your enter function using either the x or y bindkeys (for xAlign or yAlign), and then use the drawThru1 bindkey, it will know to do the alignment with the references you select instead of with a single item or point.
    Actually you could tweak the code to use a more generic name than xAlign. I put that in before I modified the code to be able to do a yAlign as well. If you change the cmdName to be "myAlign", then you can change the drawThru1Bk procedure to just check for "myAlign".
    Derek
  • Adhil
    you had defined ?cmdName as "xAlign" in your code, but when i run yAlign, it runs just as well. why is that?
    in a different note.
    can you define bindkeys that can come into effect only when a specific function,for which it is defined, is executing?
