  3. "Create Label" form's fields don't get change when using...
  • Replies 13
  • Views 6713
"Create Label" form's fields don't get change when using "hiRegTimer"
izucker
izucker over 14 years ago
I want to set the "Create Label" forms' field/s.
As long as "le0LabelForm" is defined (the form was at least once called) there is no problem doing something like:
le0LabelForm~>labelText~>value= "text"
The problem is how to set the field on first time the form is launched, meaning that the le0LabelForm is not defined yet.
I tried various solutions including using hiRegTimer with no success.
Please advise.
Itay
    Hi Itay,
    You can do this directly with a cdsenv setting - or using the leSetEnv() call:
    leSetEnv("labelLPP" "selectLayer")
    So there's no need to alter the form contents for this one.
    There are in fact numerous "label" cdsenv settings for the layout tool - search in the search assistant (Window->Assistants->Search) for "layout label vars" and it will show you what's available.
  • izucker
    OK Andrew, thanks for this answer.
    I just wonder why this works for one field and not for the other.
    Itay
    Hi Itay,
    In fact you can also use:
    leSetEnv("labelText" "blahdiblah")
    to fill in the label text field (which is what you originally wanted - I should have checked/suggested that).
    What's happening in some cases is whether the callback on the field gets called when called procedurally - and that callback then sets the env var - so maybe that's why...
