  3. DIVA layers extraction
  • Subscribers 150
  • Views 16022
nicoic85
nicoic85 over 14 years ago
Hi! I have the following problem with DIVA. I have some shapes that I want to save for example using saveDerived function, but I want to save them in another cellview. Does anybody know how can I do that? Thank you!!!
  • Quek
    Quek over 14 years ago
    Hi Nicoic85
    You can use "ext_view" option of saveDerived cmd. Please refer to COS solution 11134700.
    Best regards
    Quek
  • nicoic85
    Hi Quek! Thank you very much for your answer.
    I have two questions:
    1- Using "ext_view" can I specify the library and the cell view I want to show the results?
    2- What is  COS solution 11134700? :P
  • Quek
    Hi nicoic85
    No, it is not possible to specify the library and cellview names. Please refer to $CDSHOME/doc/divaref/divaref.pdf. COS solution refers to this.
    Best regards
    Quek
  • nicoic85
    Thanks!
