  3. How to get the attribute of any label
  • Views 17243
mvijay
mvijay over 14 years ago
I have the following piece of code to get the attribute [name/text] of any label in a layout but it does not show up in theexecution
  foreach(x cv~>shapes
  when(x~>objType=="label"
   if(x~>label~>text==net_name
    then
    println( "OK" )
        else
    println( "WRONG" )
net_name is a variable which I am passing through a form.
Question:
How to access the text attribute of any label?
I am aware of getting a name of any net.
Thanks in advance,
Vijay
  • Quek
    Quek over 14 years ago
    Hi Vijay
    Please use "x~>theLabel". I think it should resolve the problem.
    Best regards
    Quek
  • StefanSL
    StefanSL over 14 years ago
     Hi Vijay,
    what's the version you're working on?
    On 6.1.5,
    if x is your label,
    x~>theLabel will  contain it's Text/Label, so you have to check
    x~>theLabel, not
    x~>label~>text
    Hope this helps
    kind regards
    Stefan
  • mvijay
    Thanks Quek Stefan. Another query:
    How to access the other attributes viz. coordinates, orientation etc.
    Is there a leterature where I can clarify these doubts.
    Vijay
  • dmay
    dmay over 14 years ago
    The quickest way to see what attributes are on a particular object type, is to use this notation:
    obj~>?
    To see every object and its value:
    obj~>??
    A quick test would be to select a label in the Virtuoso window, then run this in the CIW:
    car(selectedSet())~>??
    Derek
  • mvijay
    Thanks Derek. Helped a lot.
    Kind Regards,
    Vijay
