  3. Saving oppoint for transistor in Spectre not working from...
  • Views 15483
Saving oppoint for transistor in Spectre not working from Modelfile?
yayla
yayla over 14 years ago
I want to save oppoint(Vdsat, Vds) for transistor in Spectre but the problem is that when I add save.scs file into ModelFile under Setup, I cannot see the results in results browser. However, if I open netlist(input.scs) and write the lines(inside save.scs) to save part of input.scs, I can find the results under Result Browser(which is described here www.cadence.com/.../3704.aspx )
Do you have any idea what the problem might be?
My setup information is
o IC 5.10.41.500.6.143.
o Cadence Virtuoso Spectre Circuit Simulator Version 10.1.1.200
yayla
  • yayla
    An update to the previous problem: I don't know how but it seems that modelfile way has started to work with same settings and files.
    yayla
    Yayla,
    If you edit the model file outside of Virtuoso (i.e. not using the edit button on the Model Libraries form), ADE doesn't know that you've changed it - and since normally spectre is run in "interactive" mode, it will not re-start because it doesn't think anything changed.
    Hitting Simulation->Stop should force it to restart spectre and hence re-read the netlist.
