  3. Help on skill code to add PIN information
  • Views 16679
narendra046
narendra046 over 14 years ago
Hi Friends,
         I have a library with many digital cells(like AND, OR,...etc). Every cell had a met1(tt) label with port name to define PIN inforamation & to pass LVS. But I need to add a MET1 PIN at wherever met1(tt) layer exists for every digital cell of library by automation.
So, Plz help on skill code to do this.
Narendra
  • dmay
    dmay over 14 years ago
    If you have a top cell with all of your digital cells placed in it (maybe for verification purposes), you can use leHiCreatePinsFromLabels(). This has an option to convert labels to pins in all the selected instances or can be used one cell at a time.
    If you need to loop through all the cells in the library with a script, you can use some code like this to get you started:
    procedure(myLabelsToPins(@optional (cv geGetEditCellView()))
      let((pin disp)
        foreach(lbl setof(x cv~>shapes x~>objType=="label")
            pin=leCreatePin(cv lbl~>lpp "rectangle" myMakeBox(lbl~>xy 0.5) lbl~>theLabel "inputOutput" list("top" "bottom" "left" "right"))
            ;The next two commands are optional
            ;You can create a textDisplay attached to the pin and delete the label
            ;or you can simply keep the label
            disp=dbCreateTextDisplay(
                pin~>term
                pin~>term
                list("text" "drawing")
                list("justify" "orient")
                lbl~>xy
                "centerCenter"
                lbl~>orient
                lbl~>font
                lbl~>height
                lbl~>isDrafted
                lbl~>isOverbar
                t   ;isVisible
                nil ;isNameVisible
                t   ;isValueVisible
                "name"
            dbDeleteObject(lbl)
      ) ;let
    ) ;proc
    procedure(myMakeBox(ref_pt amount)
        list(xCoord(ref_pt)-amount:yCoord(ref_pt)-amount
             xCoord(ref_pt)+amount:yCoord(ref_pt)+amount
    procedure(myLabelsToPinsInLibrary(libName)
      let((lib cv)
        lib=ddGetObj(libName)
        foreach(cell lib~>cells
            when(ddGetObj(libName cell~>name "layout")
                cv = dbOpenCellViewByType(libName cell~>name "layout" "maskLayout" "a")
                myLabelsToPins(cv)
                dbSave(cv)
                dbReopen(cv "r")
      ) ;let
    ) ;proc
    You'll need to run this with your library name as the string:
    myLabelsToPinsInLibrary("libName")
    This creates all pins as "inputOutput" which may not be what you want. It shouldn't matter for LVS, but might for some routing tools. Also, the pin is created 1.0 micron wide. You'll want to adjust this according to your metal width. It also assumes that the pin layer will be the same as the label layer. If this is not the case, you'll need to provide your pin layer to the leCreatePin function as the second argument. Something like list("metal1" "pin"). The pin rectangle is centered on the label. Hopefully the labels are centered on the metals. You should probably try running myLabelsToPins() on one cellview until you get the result you want, then run it on the entire library.
    Derek
  • narendra046
    Hi Dmay,
    It's working very nice & whatever I want........
    Thanks very much
    Narendra
