  3. Def jam
  • Views 15363
Def jam
tweeks
tweeks over 14 years ago
So I was creating a macro to do auto-currying called "def", and was surprised to find that name is already in use!
ILS-> getVersion(t)
"sub-version  IC6.1.5.500.10 "
ILS-> fboundp('def)
syntax:def
ILS-> pp def
pp : def is a binary function and cannot be pretty printed
ILS-> help def
nil
ILS-> arglist('def)
(s_symbol g_general \@optional g_general "sg")
ILS-> arglist('defvar)
(s_symbol \@optional g_general g_general "sg")
ILS-> eq(defvar def)
nil
ILS-> eq(getd('defvar) getd('def))
nil
ILS-> def(foo 3)
foo
ILS-> foo
3
So there's an undocumented function "def" which is apparently an alias for "defvar"? I suppose there's no harm in shadowing it, since it's already undocumented, right?
    By shadowing, do you mean defining it within a lexical scope in SKILL++ language mode? If so, that's fine, because nothing within that lexical scope would be calling def since it's private. You can't redefine it normally because it's an internal function (defined at the C level), and cannot be redefined.
  • tweeks
     Yes.
    True.
    I'm just afraid that some inernal Cadence binary function that uses "def" will no longer function properly. Would builtin functions see my definition of "def", or the original one?
    In Emacs Lisp, if you redefine a builtin (e.g. "car"), other builtins written in C don't see the redefined version, because they call "car" through the C API, so they can always access the original builtin.  Maybe SKILL works the same way?
    Only code defined in the same lexical scope (block of text) as the def definition would see it (if it was a function). Any function which was already defined in SKILL or another block of SKILL++ text, or any built-in function will not see it.
    However, I've just realised that the example you linked to had def defined as a macro (I think, from memory). You can't define lexically scoped macros - macros are global.
    So in practice the best thing will be to call it something else and give it a name with a prefix.
    Andrew=
