  3. Remove duplicates from a list
  • Replies 9
  • Views 24871
tweeks
tweeks over 14 years ago
Just wanted to share my solution to this common problem.
(defun nub (l "l")
  (let ((table (makeTable "" nil)))
    (foreach e l table[e] = t)
    table->?))
Output:
(nub (parseString "Banana Rama" "")) => ("a" "m" "n" "R" "B" " ")
This assumes order doesn't matter. If order does matter (and efficiency doesn't...), you could use this O(n^2) version, which is a literal translation of the one in the Haskell Data.List library:
(defun nub (l "l")
  (defun _nub (xs ls "ll")
    (unless (null xs)
      (destructuringBind (x @rest xs) xs
        (if (member x ls)
            (_nub xs ls)
          (cons x (_nub xs (cons x ls)))))))
  (_nub l nil))
Output:
(nub (parseString "Banana Rama" "")) => ("B" "a" "n" " " "R" "m")
If you want to preserve order and get O(n) performance, you could modify the last version to use a table instead of a list:
(defun nub (l "l")
  (defun _nub (xs ls "lo")
    (unless (null xs)
        (if (ls[x])
            (_nub xs ls)
          (cons x (_nub xs (ls[x] = t && ls)))))))
  (_nub l (makeTable "" nil)))
Output:
  • DE202408202727
    DE202408202727 over 14 years ago +1
    In the Allegro world we have a newish command called "unique". Is this available to you?
  • Adhil
    Adhil over 14 years ago +1
    i checked the manuals, and it doesn't have this function
  • markbeck
    markbeck over 14 years ago
    Nice writeup.
    I was once shown a varient of this method to remove duplicates
    (defun nub (l_list)
      (let ( (l_unique (list nil)) g_first)
        (while l_list
          g_first = (car l_list)
          (tconc l_unique g_first)
          l_list=(remove g_first l_list)
        ) ; while
        (car l_unique)
      ); let
    ); defun
    The nice thing about this method is that it works for large lists and preserves order (whereas your table version gave me a stack overflow with a large list).  That said, the first method you outlined has about 4X the performance of my method.  So if order is not important, your first method is the best way I've seen. Nice work!
    Mark
  • Adhil
    i made a procedure to remove duplicates from an actual list.
    procedure(filterRepeatedLayers(aList)
    println(aList)
    if(car(aList) != cadr(aList) && aList != nil then
    ncons(car(aList))
    filterRepeatedLayers(copy(cdr(aList)))
    else if(car(aList) == cadr(aList) && aList != nil then
    ncons(cadr(aList))
    filterRepeatedLayers(copy(cddr(aList)))
    however, when i invoke
    a = filterRepeatedLayers('("M1" "M2" "M2"))
    i get a = nil instead of a = '("M1" "M2")
  • DE202408202727
  • Adhil
  • pcbnagaraj
    pcbnagaraj over 13 years ago
     Hi Dave,
     I am not finding this command 'unique' in skill language reference manual.
    Is this removed?
    I need this in Allegro.
    Nagaraj.
    I can't answer about what's in Allegro, but it's easy to implement your own as shown in the original thread. Another implementation
    (defun MyUnique (lst)
      (let ((seen (makeTable 'seen nil)))
        (setof elem lst
          (unless (arrayref seen elem)
            (setarray seen elem t)
    This preserves the order, isn't recursive so it's probably a little faster than final nub implementation (I didn't profile it, so take that with a pinch of salt). For the hard-of-LISP, it could be written:
    procedure(MyUnique(lst)
      let(((seen makeTable('seen nil)))
        setof(elem lst
          unless(seen[elem]
            seen[elem]=t
    So it's easy enough to write yourself!
  • DE202408202727
    DE202408202727 over 13 years ago
    It's undocumented. Give it a try.
  • pcbnagaraj
     It worked!!.
    Nagaraj.
  • velkumarGN
    velkumarGN over 8 years ago in reply to DE202408202727
    its working fine . Thanks
    ciUniqueMembers( list(list("MN3" `inst ) list("MN4" `inst ) list("MN3" `inst ) list("VEl" `name ))
    list must have name and type if we use ciUniqureMembers
