  3. Mark net not blinking in some technology, how to set it...
  • Views 15519
Mark net not blinking in some technology, how to set it correctly?
PeterXia
PeterXia over 14 years ago
Hi I am using IC 514, Layout XL with IBM p13 process. The mark net option only hightlights ("barely can see"). When I changed to TSMC65N technology, the mark net is blinking correctly.
My question is what should I do to set the blinking in IBM p13 process. It is too difficult to see iwthout the blinking. Thank you a lot for letting me know how to do it.
  • Sarvani
    Sarvani over 14 years ago
        Generally marknet layer is rotates between y0 to y9 layers. You can Define packets for y0 to y9 at LSW->edit->Display resource editor. In that select outline and blinking outlinecolour.
     I hope that this will helps you.
  • PeterXia
    Hi Sarvani, thank you so much for your info.
     It worked!! You need to change to color of y0-y9 to blinking color.
