  3. CheckandSave in editor XL
  • Subscribers 150
  • Views 15751
Telekito
Telekito over 14 years ago
 Firstly, in IC6 I dont have Virtuoso_Schematic_Editor_L, I have to use Editor_XL.
I use no-graph mode and I want to change the schematic and simulate then. In IC5 i used:
cv=dbOpenCellViewByType("lib" "cell" "view" "schematic" "a")
schCheck(cv)
dbSave(cv)
and simulate with ocean.
Now, schCheck() is failing because I can't use Editor_L. Can I use schCheck() in XL_editor? or maybe can i do CheckandHow?
Thanks.
  • marcelpreda
    marcelpreda over 14 years ago
    Hi there,
    Do you get any warning/error message ?
    BR,
    Marcel
  • Telekito
     Hi again,
     of course, when I use schCheck():
    *WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_L
    *WARNING* (SCH-1317): Failed to extract lib cell view. Check that a suitable license is available.
    And when i use ocean:
    ERROR (OSSHNL-109): The cell view, 'cell', has been modified since the last extraction.
    I have tried different functions to check the schematic but all of them need  license Virtuoso_Schematic_Editor_L.
     Thanks.
    Normally if this was being done graphically, a popup would appear asking you wanted to move up the license tiers. You can avoid that by using:
    envSetVal("license" "VSELicenseCheckoutOrder" 'string "XL,L")
    before calling schCheck().
  • Telekito
     Thank you very much!
