  3. pcell parameter order
  • Views 16594
Yaosan Yeo
Yaosan Yeo over 14 years ago
I used the GUI based method to create a pcell. When I use it in my layout, the parameters seem to be in random order. Is there an easy way to arrange them in a specific order e.g. alphabetically?
     Yes, define CDF for the component. Then you can alter the order and prompts to whatever you want.
  • skillUser
    skillUser over 14 years ago
    Hi Yaosan,
    CDF parameters are normally listed in the order that they were created or added, so I presume that you didn't create CDF?
    Hope it helps!
    Lawrence.
  • Yaosan Yeo
    Thanks Andrew and Lawrence, defining CDF solves my problem.
    I used some SKILL code to generate the initial CDF from the pcell's parameters, then I used the Edit CDF GUI to set the parameter's order, which works perfectly.
    procedure( ysGenPcellCDF(libName cellName viewName)
    let( ( cellView p params cdf )
    cellView = dbOpenCellViewByType( libName cellName viewName )
    ; get list of parameters
    unless( p = car( exists( prop cellView->prop prop->name == "parameters" ) )
    error( "No parameters found for '%s:%s' in '%s'" cellName viewName libName )
    params = p->prop
    when( cdf = cdfGetCellCDF( ddGetObj( libName cellName ) )
    cdfDeleteCDF(cdf) ; remove old CDF
    cdf = cdfCreateBaseCellCDF( ddGetObj( libName cellName ) )
    foreach( param params
    cdfCreateParam( cdf
    ?name param->name
    ?type lowerCase(param->valueType)
    ?prompt param->name
    ?defValue param->value
