  3. optimization in ADE GXL
  • Views 15511
ranran
ranran over 14 years ago
Hello, I am trying to do the optimization in ADE GXL. However, I couldn't find a way to optimize the variable which I have defined in the schematic. In the ADE GXL user guide, I could only find how to optimize parameters related to a transistor, but for my case, it is a biasing voltage (vdc), and the only device parameters related to it is called srcType. Does anyone have suggestions on how I can optimize the DC value of a voltage source in order to get an expected output which I have specified in the output setup?
Thank you.
  • ranran
    problem solved... i was mislead by the ade gxl user guide, and thought it can only do optimization on parameters. I just found out it can optimize variables directly.
