  3. ADEXL counterpart of simui.menus file
  • Replies 7
  • Subscribers 150
  • Views 17598
tyanata
tyanata over 14 years ago
In the past I created custom button in the drop-down buttons bar in ADE-L, I used the approach from solution 11286092.
Now I want to create similar button on ADEXL.
The principle of routine is based on fact that you have to know the names of the default buttons on the bar ( they can be found in simui.menus file).
So I want to know what is the counterpat of simui.menus file for ADEXL.
Best regards,
tyanata
    I've updated the solution (which was written by me anyway) to show a variant approach which will work with both ADE L and the ADE XL test editor (and also appear in the RMB menus in the data view assistant, for example).
    If you want to alter the pulldown menus in ADE XL, you can do that with a user menu trigger using deRegUserTriggers() (the application is "adexl").
  • tyanata
     Hello Andrew,
    Actually I wanted not add new submenu item to certain pull-down menu, but to add new pull-down menu button.
    I used the decision of solution 11286092 in order to  do that in ADE-L in  IC5141 :
    Createion of custom menu item "Example" with 3 submenus: Item1, Item2 and Item3:
    load(prependInstallPath("/etc/tools/menus/spectre.menus"))
    (sevSetMainWindowPulldownMenus
        "Session"
        "Setup"
        "Analyses"
        "Variables"
        "Outputs"
        "Simulation"
        "Results"
        "Tools"
        "Example"
        "Help"
    (sevAddMenuItemLists
      (lambda (session name)
        (case name
          ("Example"
            list(
                        hiCreateMenuItem(
                              ?name 'MenuItem_1
                              ?itemText "Item1"
                              ?callback "println('Item1)" ;;; prints Item1 in the CIW
                  ;this is only trial function callback
                        hiCreateMenuItem(
                              ?name 'MenuItem_2
                              ?itemText "Item2"
                              ?callback "println('Item2)" ;;; prints Item2 in the CIW
                        hiCreateMenuItem(
                              ?name 'MenuItem_3
                              ?itemText "Item3"
                              ?callback "println('Item3)" ;;; prints Item3 in the CIW
           ) ;Example
          ) ; case
        ) ; lambda
      ) ; sevAddMenuItemLists
    After that I easily converted that for ADE-L in IC6.15 format just taking the new names of the buttons from the simui.menus file:
                    "S&ession"
                    "Set&up"
                    "&Analyses"
                    "&Variables"
                    "&Outputs"
                    "&Simulation"
                    "&Results"
                    "&Tools"
                    "&Help"
    Now I want to create my custom  pull-down menu button in ADE-XL. That is why I am asking if there is a counterpart of simui.menus file concerning ADE-XL.
    Best regards,
    tyanata
  • TerryL
    TerryL over 7 years ago in reply to tyanata
    tyanata, Did you ever figure out how to do this?
  • TerryL
    TerryL over 7 years ago in reply to TerryL
    Example code:
    menuItem1 = hiCreateMenuItem(  ?name ' menuItem1   ?itemText "Item text 1"  ?callback "yourFunction1")
    menuItem2 = hiCreateMenuItem(  ?name ' menuItem2   ?itemText "Item text 2"  ?callback "yourFunction2")
    newADEMenu = hiCreatePulldownMenu(  'newADEMenu
    "My Menu"  list( menuItem1 menuItem2  )  "" )
    procedure( newADEPostInstallTrigger( cellInfo )
        hiInsertBannerMenu( hiGetCurrentWindow() newADEMenu hiGetNumMenus( cellInfo->window ))
    deRegUserTriggers( "adexl" nil nil 'newADEPostInstallTrigger)
    Terry
    Andrew Beckett over 7 years ago in reply to TerryL
    Hi Terry,
    Actually you shouldn't use the post-install trigger to add menus. Instead you should use the user menu trigger (the third rather than the fourth argument to deRegUserTriggers) and your trigger function should return a list of pulldown menus. So you'd do something like:
    procedure(newADEMenuTrigger(cellInfo)
      list(newADEMenu)
    deRegUserTriggers("adexl" nil 'newADEMenuTrigger)
    that way the Design Editor ("de") takes care of inserting the banner menus - you don't have to do it. If you use the post-install trigger, things can fight with each other, I've found.
    Essentially this was the approach I was suggesting in my reply 7 years ago - that pulldown menus are added with deRegUserTriggers.
  • TerryL
    TerryL over 7 years ago in reply to Andrew Beckett
    Hi Andrew:
       Thanks for the feedback.  Can you provide a simple example?  I'm struggling a bit, with getting that working.
    Terry
  • TerryL
    I got it working.
    Thanks again for the feedback Andrew.
    Terry
