  3. Triggering callbacks
  • Views 17516
navi2582
navi2582 over 14 years ago
After loading the "CCSinvokeCdfCallbacks.il", I opened the schematic and again ran "CCSinvokeCdfCallbacks(geGetEditCellView())" but I am getting the following error messages,
\e *Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
\e *Error* evalstring: argument #1 should be a string (type template = "ts") - nil
\e *Error* eval: unbound variable - process
Am missing something?
I am using IC6.1.5-64b.500.9
Naveen
    Hi Naveen,
    It's hard to know without seeing the specific case, but you might need to tell it to call the callInitProc too - sometimes this has to be done for the callbacks to work. You can do that by calling:
    CCSinvokeCdfCallbacks(geGetEditCellView() ?callInitProc t)
    The other possibility is that that callback is referring to cdfgForm and looking at the cellName (say) - this is dubious practice, but it does happen sometimes. In that case, try adding ?addFormFields t to the arg list.
    If neither work, I suggest you contact customer support. You'll need to provide info on the PDK you're using. If the AE handling the service request isn't sure, they can always contact me (as I wrote the code) for help - but we'd need enough data to reproduce the problem.
  • navi2582
    Is there any remote chance that it wouldn't work if I run it on the top-level hierarchy, which doesn't have any individual instances placed (only blocks)?
    The reason behind this conclusion is: I copied the top-level schematic (with all the hierarchy) into a new library and ran "CCSCdfCallbackEntireLib.il". It worked (sort of)!!! I still got the same error messages (seen from the icfb window) when it was running on the top-level schematic but was able to successfully reset few other attributes on other schematic cellviews.
    I really appreciate your help (always) !!!
    Naveen
    Naveen,
    If you run on the top level block, it's only going to call the callbacks for the instances placed - so if there's a failing there, it's because of any CDF callbacks on those devices.
    The errors are probably coming as a consequence of the callbacks themselves. Seeing the data is probably the only way to debug this - but you could try typing:
    _stacktrace=50
    tracelength=50
    tracelevel=50
    and triggering the callbacks and seeing if the additional information makes it any clearer?
