  3. how to set spacing on multiple fingers for mos device for...
  • Subscribers 148
  • Views 14536
how to set spacing on multiple fingers for mos device for every 5 fingers to insert a well tap
hanhMPS
hanhMPS over 14 years ago
Hi all,
could you please help I try serveral conditions with "when, if , while.. but can not get the result
The assigment for Pcell coding was adjusting the spacing on every 5 fingers on polyGate for mos device to add a well tap.
maximum fingesr gate support is 50.
Many thanks to your help
jiH
    Not enough information to go on. Sounds as if you're asking somebody to do your assignment for you; assuming somebody on the forum is generous enough to find the time to do this, providing sufficient information would have been a good start. Better still, show what you've tried, and then maybe somebody can point out the mistake (assuming you've given enough information as to what you're trying to do).
    Kind Regards,
