  3. Convert inst to mosaic
  • Views 19002
Gurup
Gurup over 14 years ago
 Hi
 I am trying to change the object type of the MOS from instance to mosaic, and I used following command
dbCreateParamSimpleMosaic(
d_cellView
d_masterCellView
t_name
l_origin
l_orient
x_rows
x_cols
x_rowSpacing
x_colSpacing
l_params)
 I am not able to pass w and l info of the existing MOS instance.
please tell me how to pass the the parameters
  • Quek
    Quek over 13 years ago
    Hi Gurup
    If your command is correct, then it is most likely because of callback triggering. You might need to use the trigger script in COS solution 11018344.
    Best regards
    Quek
  • Yaosan Yeo
    Yaosan Yeo over 13 years ago
    This works for me (assume you have one MOS inst selected):
    inst = css()
    dbCreateSimpleMosaic( geGetEditCellView() inst->master "M1" inst->xy inst->orient 1 1 0.1 0.1 )
    If you MOS is a pcell, setting the correct master should give your new mosaic the proper w and l values.
  • Gurup
    Gurup over 13 years ago
     Thanks Yeo,
    its working fine
