  3. monteSelectResults!
  • Views 14516
monteSelectResults!
imagesensor123
imagesensor123 over 14 years ago
    could anyone give me a short example of using "monteSelectResults" ? I just know we can use this command to open and select the monte carlo analysis results "mcdata" . my question is that , for example,  the mcdata contains 100 scalar data from 100 times montecarlo run, how can I pick each scalar data up, such as 1.00085 for the first run and 1.00036 for the second run. i want to select everyone and save it in a list or a variable. in fact, i didn't find how the mcdata is saved in cadence database. any suggestion?
regards,
zfeng
    Zfeng,
    monteSelectResults() is just to select the entire results set. If you want to do detailed analysis of each result and access the scalar data, you could use my abStats.il code in solution 11026072
