  3. Model Library
  • Views 16104
Model Library
Ashish86
Ashish86 over 14 years ago
 I have written a script that inlcudes model libraries for spectre simulation for the current switch and stop view.
How do I remove the old library using SKILL script when I add a new one for different switch and stop view.
    You've not really given sufficient detail for anyone to figure out what you're actually doing or aiming to do - so I'm not really sure how to answer your question - maybe somebody else can, or maybe you can just clarify your question?
  • Ashish86
    if i want to place my own .scs files into the model library. i am able to do that but if i want to remove the previously placed file with a new one how do i do that using SKILL..is there any specific command.
    Are you trying to do this before you start ADE, or during a running ADE session?
  • Ashish86
     during ADE session. I load the script from CIW and then create the netlist thorugh ADE session.
    asiSetEnvOptionVal(asiGetCurrentSession() "modelFiles" list(list("/path/to/me.scs" "NN") list("/path/to/you.scs")))
    In the example, the first file has a section name, the second doesn't.
