  3. SKILL schematic connectivity entry
  • Views 15207
soathana
soathana over 13 years ago
In schematic you can use dbCreateLine/dbCreatePath to create the connectivity. Among other they take for parameters a list of points(at least 2).
Is there any already implemented way, to do this without having to go point by point? (meaning if there is another way just by choosing pin  names to connect automatically)
Sotiris
  • skillUser
    skillUser over 13 years ago
     Hi Sotiris,
    Yes, you can use the function schCreateWire() to do the routing for you and choose the t_routeMethod argument as "route", then you should only need to supply the start and finish points of the wire.
    Hope this helps you!
    Lawrence.
  • soathana
    Solved!Thanks Lawrence!
     Sotiris
