  3. ocean script
  • Views 16115
ocean script
Stefan Bormann
Stefan Bormann over 13 years ago
I have an oceanscript (originally created by adexl) and I want to write the output from one fuction to a file:
I have this part:
of = outfile( "output_log" "w")
port:"output_log"
ocnxlOutputSummary(?yieldSummary t ?exprSummary nil ?specSummary nil ?detailed nil)
Yield summary:
  test:nch_model_test:1:
    Name            Yield  Min  Target     Max    Mean   sigma To Target   sigma   Errors
    IDC("/M0/D")_C17:mctt 100 2.803u         info 11.33u 5.958u                     2.253u       0
Estimated yield = 100.000000% (10/10), 0 errors
Estimated yield (No opregions) = 100.000000% (10/10)t
if I try to use fprintf(of "%s" ocnxlOutputSummary(?yieldSummary t ?exprSummary nil ?specSummary nil ?detailed nil))
it create an empty file ...
I also tried to use the command ocnPrint but this created only a file with the status (t, nil) of the print.
 any ideas to get the command line print from ocean out to a file?
-Stefan
    Stefan,
    Not sure which version you're using, but ocnxlOutputSummary() has a ?fileName argument now to write to a file. If that's not available, I have a workaround - but please state which version you're using.
  • Stefan Bormann
    thanks for the quick reply.
    I looked into the Ocean refence (6.1.5) but under ocnxlOutputSummary() is no argument like ?fileName listed.
    I'm using virtuoso 6.1.5.500.5 and typing version at the ocean prompt gives me this: "v2008.4_28.20".
    Regards
    -Stefan
    Stefan,
    This was added in IC615 ISR8 (6.1.5.500.8). Can you use a later subversion? Note that typing "version" at the OCEAN prompt is presumably telling you the value of some SKILL variable in your environment/customization (it's not from us). You'd type getVersion() or getVersion(t) to get the subversion in SKILL.
    The workaround if you really cannot use a later subversion is to use:
    Currently the ocnxlOutputSummary does not support writing the summary information to a file. If you want to do this, the following wrapper around ocnxlOutputSummary may be used. This takes the same arguments as ocnxlOutputSummary, but adds an extra ?output argument to allow a file output handle to be specified:
    procedure(TrOcnxlOutputSummary(@key (output poport) @rest args)
      let(((poport output))
        apply(’ocnxlOutputSummary args)
    An example of using this:
    prt=outfile("summaryReport.txt")
    TrOcnxlOutputSummary(?output prt ?exprSummary t ?detailed nil)
    close(prt)
  • Stefan Bormann
     Thanks. It works good. And parallel I will force to install the latest  virtuoso version here at our site.
    Regards
    -Stefan
