  3. Standard cell library
  • Subscribers 150
  • Views 18498
Sarvani
Sarvani over 13 years ago
Hi all,
I need standard cell library symbols. Is there any library used in install directory like analogLib in INSTALL_DIR/IC5141/tools.lnx86/dfII/etc/cdslib/artist/analogLib. I mean I need symbols for all gates.
Thank you,
venu
    Sarvani,
    The closest is the sample library at  tools/dfII/samples/cdslib/sample
    Other than that, you could look at our GSCLIB090 library (Generic Standard Cell Library for 90nm GPDK) which is on http://pdk.cadence.com - you'll probably have to register to get it and accept any agreement that comes with it. This standard cell library is intended for demonstration purposes only.
  • Sarvani
    I have got sample library but I didn't find any GSCLIB090 library in pdk.cadence.com.
    But Sample library is sufficient for me. Thank you very much for your golden suggestions.
    Thank you,
    sarvanivenu
    For completeness, if you are logged into pdk.cadence.com you can go to the Downloads page, and then change the left hand cyclic from "All Foundries" to "Generic", and then hit the "Search". You should then see the library listed.
    But probably the sample library is good enough for your needs, as you said.
