  3. Help on pin name conversion for whole library
  • Views 14580
Sarvani
Sarvani over 13 years ago
Hi all,
1)        I have wrote below code for conversion of pin names from "Z" to"ZN".
procedure(loopCells(libName @optional (viewList list("symbol")))
  let((libId cvId v points)
    libId = ddGetObj(libName)
    foreach(cell libId~>cells
        foreach(viewName cell~>views~>name
            when(member(viewName viewList)
                when(cvId = dbOpenCellViewByType(libId cell~>name viewName nil "a")
;schCreateSymbolLabel(cvId points "analog instance label" "cdsName()" "lowerCenter" "R0" "roman" 0.5 "NLPLabel")
;schCreateSymbolLabel(cvId points1 "instance label" "[@instanceName]" "lowerCenter" "R0" "roman" 0.5 "NLPLabel")
labels1=setof(x cvId~>shapes x~>objType=="label" )
labels=setof(x labels1 x~>theLabel=="Z" )
foreach(x labels
x~>theLabel="ZN"
pins1=setof(x cvId~>shapes x~>pin)
 pins=setof(x pins1 x~>net~>name == "Z")
foreach(x pins
x~>net~>name="ZN"
schVIC(cvId)
dbSave(cvId)
dbClose(cvId)
t
);let
);procedure
ERROR:
*Error* setSGq: (DB-370034): dbSetq: Cannot set attribute - name
2)I need to copy "symbol" to "auLVS", "auCdl" for every cell in library. Is there any code or reference code for doing this function.
Thank you,
venu
  • Sarvani
    I have solved this problem. The exact code is:
     pins=setof(x pins1 x~>pin~>term~>name == "Z")
    foreach(x pins
    x~>pin~>term~>name="ZN"
    foreach(x labels
    x~>theLabel="ZN"
    schVIC(cvId)
    dbSave(cvId)
    dbClose(cvId)
    t
    );let
    Thank you,
    sarvani
    );procedure
