  3. Failed to build VDB
  • Subscribers 150
  • Views 19633
Failed to build VDB
Sarvani
Sarvani over 14 years ago
Hi all,
           I have installed a PDK and set some settings in Switches in DRC form. I have been getting below warnings in CIW while running DRC.
Warnings:
 Assura DRC: State saved "Last"
Compiling rules...
ERROR  Wrong techLayers() item in techfile: (MT3_noconn 1084)
Layer# must be an unsigned integer between 0 and 255.
WARNING Undefined layer in dfII.
    Layer name 'prBoundary' doesn't exist, treating as an empty layer.
    PRBound = layer("prBoundary" type("drawing"))
    Layer name 'M3_noconn' doesn't exist, treating as an empty layer.
    M3_nodummyi = layer("M3_noconn" type("no_dummy"))
    Layer name 'M4_noconn' doesn't exist, treating as an empty layer.
    M4_nodummyi = layer("M4_noconn" type("no_dummy"))
    Layer name 'MT' doesn't exist, treating as an empty layer.
    MT_ll = textToPin("MT" type("label"))
    DMTi = layer("MT" type("dummy"))
    Layer name 'MT3_noconn' doesn't exist, treating as an empty layer.
    MT3_msi = layer("MT3_noconn" type("mslits"))
    MT3_lsi = layer("MT3_noconn" type("lvs"))
    MT3_nyi = layer("MT3_noconn" type("no_dummy"))
    MT3_opci = layer("MT3_noconn" type("opc"))
info:   dubiousData is handled by default in Assura.
  1073. dubiousData("M1")
*WARNING* (reader): extra ')' ignored at line 2751 of file /remote/projects/semtech/ts18pm/CDB/HOTCODE/techs/ts18pm_3M1T3/assura/default_scr/../../../ts18pm/assura/default_scr/DRC_TS18SLPM_ASSURA
*WARNING* (reader): extra ')' ignored at line 3825 of file /remote/projects/semtech/ts18pm/CDB/HOTCODE/techs/ts18pm_3M1T3/assura/default_scr/../../../ts18pm/assura/default_scr/DRC_TS18SLPM_ASSURA
WARNING Duplicate errorLayer 'DEV_fuse'; latter replaces former.
  8028. errorLayer(DEV_fuse "MEF.N.1: metal eFuse is allowed in metalization options per design rule")
Errors exist in the rules file '/remote/projects/semtech/ts18pm/CDB/HOTCODE/techs/ts18pm/assura/t.00_00_01_scr/DRC_TS18SL_ASSURA'.
*WARNING* Failed to build VDB. Cannot submit DRC Run.
Assura DRC: State loaded "Last"
Thank you,
sarvani
  • Quek
    Quek over 14 years ago
    Hi Sarvani
    Would you please use vi or any other editor to check for missing/extra brackets in the rules file?
    WARNING* (reader): extra ')' ignored at line 2751 ...
    Best regards
    Quek
  • Sarvani
    Hi Quek,
                 Problem in assura version.  Now it works good. Is it rule files also depending on assura version.
    Thank You,
    sarvani
  • Quek
    Hi Sarvani
    Yes, sometimes rules file is dependent on the version of Assura. E.g. if rule deck uses geomConnect(incremental...) cmd, it will not be able to run on old versions of Assura.
    Best regards
    Quek
  • Sarvani
    Thank you for your golden suggestions Quek.
    We need to use  below versions..
    - Virtuoso - IC6.1.5-64b.500.9
    - Assura - 4.1_USR2_HF14
    But we are using
     -virtuoso -6.1.4 ,    IC6.1.4.500.10  (32-bit addresses)
    - Assura -  4.1_USR2 (assura version av4.1:Production:dfII6.1.4:IC6.1.4.500.7 12/13/2010 05:18 (sfrh12) $)
    Is there any chance to get voiletions If we are using these versions. We have been getting Malformed Device in LVS error report. Is there any relation between that Malformed Device error and version.
    I have got some warnigs:
    Assura Errors & Warnings Search (PLEASE CAREFULLY REVIEW THESE MESSAGES)
    WARNINGS & ERRORS found in Assura NVN Run Log file
    *WARNING* WARNING (AVLVSNN-10046) : command 'mergeParallel("VDN5" merge combineParallelM)' overlaps command 'mergeParallel("VDN5" merge combineParallelBJT)' - merge parallel behavior becomes unpredictable. Edit your rule file(s) and specify only one mergeParallel function for each device or device type.
    *WARNING* WARNING (AVLVSNN-10046) : command 'mergeParallel("VNPNHG2" merge combineParallelM)' overlaps command 'mergeParallel("VNPNHG2" merge combineParallelBJT)' - merge parallel behavior becomes unpredictable. Edit your rule file(s) and specify only one mergeParallel function for each device or device type.
    *WARNING* WARNING (AVLVSNN-10046) : command 'mergeParallel("VNPNHG5" merge combineParallelM)' overlaps command 'mergeParallel("VNPNHG5" merge combineParallelBJT)' - merge parallel behavior becomes unpredictable. Edit your rule file(s) and specify only one mergeParallel function for each device or device type.
    *WARNING* WARNING (AVLVSNN-10046) : command 'mergeParallel("VNPNHG10" merge combineParallelM)' overlaps command 'mergeParallel("VNPNHG10" merge combineParallelBJT)' - merge parallel behavior becomes unpredictable. Edit your rule file(s) and specify only one mergeParallel function for each device or device type.
     WARNING (AVLVSNN-10029) : 'filter' command has been converted into 'filterOptions' with the same function. 'filter' command is not supported. Use 'filterOptions' instead.
    *WARNING* incorrect use model for merge and compare commands.
      A SKILL procedure is specified in the mergeSeries or mergeParallel
      operation but compareParameter does not specify a SKILL procedure.
      This may result in incorrect results especially when M factor is present.
      The correct use model is to use a SKILL procedure for compareParameter if
      mergeSeries or mergeParallel uses a SKILL procedure.
      Commands affected are:
         compareParameter("VNPNHG10"  percent( "M" 0))
         compareParameter("VNPNHG5"  percent( "M" 0))
         compareParameter("VNPNHG2"  percent( "M" 0))
         compareParameter("vpnp5_10_hp"  percent( "M" 0))
         compareParameter("vpnp5_5_hp"  percent( "M" 0))
         compareParameter("vpnp5_2_hp"  percent( "M" 0))
         compareParameter("VDN5"  percent( "M" 0))
         compareParameter("jvarrf3t"  percent( "L" 0 "W" 0 "NF" 0 "M" 0))
         compareParameter("dprfesd_s"  percent( "L" 0 "M" 0))
         compareParameter("dio_dpnwls"  percent( "dtype" 0))
         compareParameter("dwtnpsb_5v40"  percent( "dtype" 0))
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM33T' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM32T' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM43T' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM42T' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM53' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM5' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM63' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CM6' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CMG' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'mfc25rf' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'mfc26rf' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'mimstk6rf' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'var18rf' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'ind46s3t' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'ind45s3t' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'indm6s3t' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'indm5s3t' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'ind35' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'ind36' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'indg' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'indm53t' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'indm63t' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'indm5' not found.
     WARNING (AVLVSNN-10050) : indDevice - cell 'indm6' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'nld_5v40_a' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'pld_5v60_a' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'pld_5v40_a' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'pld2_5v12_prim' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'pld_5v12_lr' not found.
    *WARNING* genericDevice("nld_5V12_sa_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("nld_5V_sV_hs_Lox_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("nld_5V_sV_hs_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("nld_5V_sV_Lox_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("nld_5V_svd_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("nld_5V_sclV_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("pld_5V_sV4T_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("pld2_5V_sclV_prim") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("pld_5V_sclV_prim") - cell does not exist. This command will be ignored.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'nat33rf' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'nat18rf' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'p33rf' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'n33rf' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'p18rf' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'n18rf' not found.
     WARNING (AVLVSNN-10050) : dioDevice - cell 'dio_dpnwls' not found.
     WARNING (AVLVSNN-10050) : dioDevice - cell 'jvarrf3t' not found.
     WARNING (AVLVSNN-10050) : dioDevice - cell 'dprfesd_s' not found.
     WARNING (AVLVSNN-10050) : resDevice - cell 'm6ef' not found.
     WARNING (AVLVSNN-10050) : resDevice - cell 'm5ef' not found.
     WARNING (AVLVSNN-10050) : resDevice - cell 'm4ef' not found.
     WARNING (AVLVSNN-10050) : resDevice - cell 'm3ef' not found.
     WARNING (AVLVSNN-10050) : resDevice - cell 'm2ef' not found.
     WARNING (AVLVSNN-10050) : resDevice - cell 'mlef' not found.
     WARNING (AVLVSNN-10050) : resDevice - cell 'mtef' not found.
    *WARNING* genericDevice("bzn_5v5") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("dwtnpsb_5v40") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("dwtppsb_5v40") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("esd_snk_1") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("esd_hvscr_1") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("esd_lpnp_1") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("ds_5v40") - cell does not exist. This command will be ignored.
     WARNING (AVLVSNN-10050) : dioDevice - cell 'dz_5v5' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CHF' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CLF' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'nwcap3352t' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'nwcap1852t' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'cipw5v3t' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CZ' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CY' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'NCAPIMP332T' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'ch53t' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CH3' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CL3' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CH' not found.
     WARNING (AVLVSNN-10050) : capDevice - cell 'CL' not found.
    *ERROR* Device 'nld_5V12_sa_prim(Generic)' on Schematic is unbound to any Layout device.
    Please confirm me problem is in rule file or version .
    Thank you,
    Sarvani.
  • Quek
    Hi Sarvani
    In general, malformed device errors are not related to the version of Assura. I suspect that you are facing a device climbing problem. This means that some parts of a lower level device (e.g. recognition layer or source/drain) has been accidentally promoted to top level and hence the incomplete device at top or lower level becomes the malformed device.
    You can try either of the following 2 methods to see if it helps:
    a. Re-run Assura using ?preserveShapes avParameter
    b. Use "targetLayer" cmd in your extractDevice cmd to force the device to stay at the same level.
    Best regards
    Quek
  • Sarvani
     Hi Quek,
     Thank you Quek. Problem is solved. Now it works good. Problem is in layout. Previously we added one extra Layer on device which is not required.
    Thank you
    Sarvani
