  3. Plotting data from array
  • Views 16967
IvarL
IvarL over 14 years ago
I am having problems plotting or retreiving data from an array. I declare an x-axis and a function, e.g.
declare(xaxis[len])
declare(output[len])
and then do some calculations
for(i 0 len-1
   xaxis = i
   output = algorithm(xaxis)
where algorithm() is a general algorithm doing some processing. Now I want to plot "output". I have tried both
wave_output = drCreateWaveform(output xaxis)
wave_output = abMakeWaveform(output xaxis)
but none of these work because they want the output-values as a list rather than a vector/array. The output array contains data, so I can see the values output[0], output[1] etc, but I haven't found out how to convert them to a wave. How do I go about to produce a waveform from the output I have generated with the algorithm?
Thanks.
    You could use vectorToList(output) to get a list. And the same for the xaxis. Or you could directly create the X and Y vectors as you go along:
    xaxis=drCreateVec('double len)
    output=drCreateVec('double len)
    for(i 0 len-1
      drSetElem(xaxis i i)
      drSetElem(output i algorithm(i))
    wave=drCreateWaveform(xaxis output)
