  3. Plotting Output Impedance of an Inverter
  • Views 24570
nevinalex1234
nevinalex1234 over 14 years ago
 Hi
I am using cadence 6.1. I have used DC sweep operation for plotting various parameters, etc variations of VDS with respect to l,w etc..
I have designed a small inverter and i want to measure the output impedance of the same vs Vds . How do i proceed ?
There is no option for plotting ron||rop ?
  • Eshar
    Eshar over 14 years ago
    There are a couple of ways I can think of.
    First, you can just follow the definition of output impedance. Just place a voltage source at the output node and measure the current leaving the source. After that, it is just ohm's law (R = V/I). This will be the most relevant indication if you really only care about the output.
    However, if you want to know the individual transistor ron and rop, cadence does calculate the rds of the transistors at the bias point you set. Just run a DC analysis in Analog Design Environment (ADE) with the save operating bias checkbox checked. Now run the simulation. If this was done correctly, you should now be able to click on Results>Annotate>DC Operating Points. Finally, go to the schematic and click on the transistor you are interested in. This would produce a pop-up window with information about the transistor bias state, which includes its rds value.
  • MicheleA
    MicheleA over 14 years ago
    I understand you would like to plot the output resistance (rds) of your n and p MOS, versus some DC sweep variable.
    It may be that, while if you perform a single point DC analysis, you are able to print the small signal parameters of your devices, if you try the same after a DC sweep, you are unable to visualize those data. If that's the issue you are facing, I have gone trhough the same: basically, you have to instruct the simulator to save OP device data for each point in the sweep. By default they are discarded (as to spare some room).
    Here is my post, along with Andrew Beckett's (perfect) reply :)
    /forums/p/21507/1307561.aspx#1307561
    Once you have rds_n and rds_p, you can just calculate the parallel of those two and insert the expression in the outputs.
    Hope this helps,
    M
