  3. Controlling Parameter placing in a symbol view
  • Views 18903
MicheleA
MicheleA over 13 years ago
Hi all,
let's say I want to create my own cell for an inductor, I call it my_ind. The schematic contains an ideal (analogLib) ind whose inductance value I set to be
pPar("my_val")
I add two pins to this schematic and I am finished. Then, I create a symbol, a simple box with two pins.
The symbol contains "cdsParam(#)" labels, which I thought should represent...well...the CDS parameters one sees in the form.
I thought this was the case, because if you look at a "standard" symbol like a pulse voltage source:
 it really looks like those cdsParam() labels translate into the places where the parameters go...
So I have checked that the type of the two labels is the same (analog device annotate, ILLabel) and everything looks fine to me.
What am I doing wrong? I would like to control the position of the displayed parameters, just like other symbols seem to do.
While I am at this, I may try also to understand what all the different label types mean, how and when to use them ( ILLabel, NLPLabel..) so I'd be grateful for a pointer to the right manual/section.
I hope this is not too confusing and look forward to your replies,
Kind regards,
Michele
  • MicheleA
    ...ok...Apologies for not having done my homework beforehand...I found a suitable answer here:
    http://www.cadence.com/Community/forums/p/18290/1260782.aspx#1260782
    One has to "activate" those cdsParam labels by going Edit->Component Display..
    Sorry for the waste of bandwidth,
    Michele
