  3. layer num & layer ID
  • Views 6022
hi2yogi
hi2yogi over 14 years ago
I am checking layer ID in a layout data base with following command.
cv~>lpps~>layerHeader~>lpps~>layerNum
or
cv~>layerHeaders~>lpps~>layerNum
or
cv~>shapes~>layerNum
But it is not giving layer id as in *_Tech.layermap file.
i.e.  for  M2 pin & M2 drawing above command giving 15 15 , but in tech file  M2 pin  ..layer id is 17  32 &  for M2 drawing  layer id is 17 0.
please suggest me right way to check that ...
    The layerNum is the database layer number (there's a similar purpose number too which you can find with techGetPurposeNum()). However, that is the number used to store the layer in the database itself. The layerMap file is for the stream (or "GDSII") layer number - there is no requirement that this number is the same as the database number. So the technology database encodes the mapping from layer and purpose names to database layer numbers and purpose numbers. The layermap encodes the mapping from layer and purpose names to stream layer and datatype numbers.
  • hi2yogi
    Thanks Andrew
    I understand your explination. I need help in that case...
    1)  how i should find out  database layer numbers and purpose numbers  ?
    2)  how i should ensure that it (database layer numbers and purpose numbers)  exist in techlayermap
    ie let suppose i have ported layout data base from 32nm to 28nm then i would like to ensure  that there is no unkown layer ( layers which does not support by 28nm)
    Please help me with above !!!!!!
    Once again thanks for time
    You can find the database layer numbers and purpose numbers  by dumping the technology file (from Tools->Technology File Manager->Dump in the CIW).
    Your second question doesn't make sense, because it's the mapping from layer purpose names to stream layer/datatype numbers that are in the layermap file.
    I don't know how you've "ported" the layout database from one technology to the other - so it's hard to answer the final question.
