  3. Automatically export CDL by skill
  • Views 17998
nidon
nidon over 14 years ago
Dear sir:
 I want to write a code to export CDL.
Firstly,I use si -batch command,but it seems to take a long time to export every cdl netlist.
So,I write another code which seems executes faster as follow:
libName="lvs_test"
runDir="./lvs_run/"
if(!isContextLoaded("transUI") then
    loadContext(strcat(prependInstallPath("etc/context/transUI.cxt")))
cellList='("cell1" "cell2" "cell3" "cell4")
foreach(name cellList
;transCdlOutDisplay(transCdlOutForm)
transCdlOutForm->cdlOLibName->value = libName
transCdlOutForm->cdlOTopCell->value = name
transCdlOutForm->cdlOViewName->value = "schematic"
transCdlOutForm->cdlONetlistFile->value = strcat(name ".cdl")
transCdlOutForm->cdlORunDir->value = runDir
transCdlOutForm->cdlOResistorValue->value = 0.0
transCdlOutForm->cdlODiodeCheck->value = "area"
transCdlOutForm->cdlOCheckLDD->value =  t
hiFormDone(transCdlOutForm)
hiRegTimer("hiDBoxOK(simNetNoOp6)" 10)
hiRegTimer("hiDBoxOK(simNetNoOp5)" 11)
There is an other problem.As the celllist,I want to export cell1,cell2,cell3 and cell4 .But,the script just can export cell2,cell3,cell4,missing the cell1.Can anyone help me to find the problem in my script?
 Thank you very much!
    If using auCdl, I don't really see why it should be slower to invoke si, since that's all that happens when you use the User interface...
    Maybe you should contact customer support - doing this by interfacing with the UI is likely to be problematic.
